Revo-Smarty
Old Nov 21, 2008 | 11:57 AM
Torque master's Avatar
Revo-Smarty
Just picked up a Revo -Smarty and running it on the number #9 Cathcer Setting and lovin it, best programmerI have ever used so far.
Can anyone explain the differant levels of power I hear people speak about 4.4 4.3 etc What would the catcher #9 setting be classified as 4.4?
Old Nov 21, 2008 | 01:17 PM
06MegaCTD's Avatar
those are the beta versions, like you have the revo software, but there is also i think like 4.3, 4.2, 4.4, revo tnt, so you just have the revo software.
Old Nov 21, 2008 | 04:31 PM
ADDT2TRQUE's Avatar
what is the difference from the Beta and the Revo programs? Also what is the difference between the 4.11 4.2 4.3 4.4???
Old Nov 21, 2008 | 04:44 PM
Good to See I am not the Only confused Dipstick Out there.
Old Nov 21, 2008 | 08:14 PM
06MegaCTD's Avatar
some version run better on different peoples truck with different mods, but i think if you are mostly stock the revo is fine from what i have been reading.
Old Nov 22, 2008 | 12:39 PM
ADDT2TRQUE's Avatar
anybody else have a bit more details?
Old Nov 22, 2008 | 12:53 PM
gus's 03's Avatar
4.2, 4.3, 4.4 etc were beta files. ie: test programs used to establish production files. the knowledge gained from them went into stuff like the revo program.
tnt is a higher ouput version of revo, and tnt-r is iceing on the cake with options such as raised rpm limit etc.
tnt and tnt-r need fuel system upgrads, trany upgrades etc.
std revo is rated 30-170 hp. the tnt files are STARTING at 100 hp and rated 230+ hp @ higher levels providing you have the suporting mods.
Old Nov 22, 2008 | 01:18 PM
Supporting Mods
What Would be the Base Supporting Mods needed / required to comfortably Run the 230 HP-Setting on the Smarty?
Old Nov 22, 2008 | 05:18 PM
Jason_K's Avatar
if you had a turbo, you would have no problem. you can still run it w/ a stock turbo....just keep an eye on you egt's and boost. valve spring also wouldn't be a bad investment, i've hit 3500rpm's w/ the tnt and that was a little too high for my liking.
Spooler
13
Apr 12, 2009 12:55 PM
rallydriver
Nov 1, 2008 12:41 PM
jmccart
Jun 23, 2008 11:11 AM
bigwheels94
Jun 4, 2008 09:47 AM
zack birge
May 11, 2008 09:57 PM
