Removing catalytic converter pros-vs-cons?
Has anyone removed their catalytic converter? A friend removed his off his 5.9 and said it made a big difference in performance and a little better milage too..Also will it lower EGT's?...
Administrator/Jarhead
No cons unless you have a state that checks for it in vehicle inspections or emissions inspections.
It will reduce EGT's and improve MPG's slightly. More so if it is clogged.
Removing the cat will lower Egt's. I saw a 150* drop. It will also make your truck slightly louder but worth it to lower the EGT's..Performance wise cant say that I noticed a difference.
Two dog Dodget (08-31-2023)
We dont have to do emmissions testing here. So I thought I would just remove it and if testing ever is mandated then just have it put back in. I good friend of mines owns and operates "Economy Muffler" here in Yuma, AZ.
As for differences, I haven't seen a huge increase in economy, maybe .5 mpg, 1 if I'm lucky. Truck seems to spool faster, but could be placebo. LOVE the sound... and the smell. Do it - you won't regret it. If you do, put it back on. Can't de-gut it though
As for where to buy I don't know if where I bought mine is a DTR sponsor, so pm me if you need more info.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
you can't smell the difference with a diesel. if they do a visual, a gutted cat looks like a complete cat. You can use smarty on 1/2 power to pass emissions.
there is also CARB legal replacement high flow cats available
Pro - sounds mean, slightly lower EGT's
Cons - really chapped neighbours, drone, etc...
I took mine out just to end up putting it back in. I noticed a 50 degree difference in EGT's but I hated how noisy it was. It was too loud in the cab especially on the kids ears.
Seriously?!?
I couldn't smell much - if anything at all - outside the truck before, but now I get a big ole whiff every time I roll up to a stop with the windows down. Step outside and it smells like an old school bus.
I don't disagree here.
Doesn't the OEM cat have pretty decent flow... why spend $350+?
Not trying to flame anybody or their decision to gut, just my $0.02. I was on the fence for a LONG time regarding the delete/gut decision. Ultimately I decided that I can play dumb until Texas really decides to crack down. Now for the other 49 states, I haven't a clue
Regarding the drone - it starts somewhere around 73-74 mph. Perfect for keeping me from speeding on long trips and keeping my mpgs up!
If you do decide to gut, wear a respirator.
well if i am wrong i am wrong. i can't smell a difference on a diesel other than the new ones with dpf and stuff. my cat got killed at 60 miles of owning the truck.
