Removal of Leveling Kit
Im tired of my front end pointing to the sky when hooking to heavy loads. Will the alignment be affected when taking off the leveling kit?
When you added kit you had to
realign front end, you will need to do the same when when you take spacers out. |
Just a suggestion, but why not get some air bags and keep the truck level.
Originally Posted by GreyTD
(Post 2180544)
If time is a factor, firestone air bags take about an hour to install. Including getting the tools( mainly wrenches) and cracking a cold one. no tires to remove. i put mine air lines to the wheels well until I get on board compressor, that way check tires and bags at same time.
