Question re: Vulcan 90* fitting for fuel pressure gauge
I have installed the Vulcan 90* pre-drilled fitting so that I can install my fuel pressure gauge on it. My question is: The sensor seems to screw almost all the way into the fitting, won't this block the flow of fuel? It seems that it will really decrease the amount of fuel getting to the CP3.
yeah I had to use a different brass fitting on mine...for some reason the sensor had slightly different threads...( i think they just tapped one of the fittings a little to much)
I used a male to female adapter and it seems to get tighter sooner. so as not to block flow.. clear as mud?? |
yeah I had one and found the same thing and mine kept leaking so I just went back to picking up my pressure of the GDP fitting in my stock fuel canister.
I will have to check mine,I don't remeber it making up too much.
If you run a NPT tap too far the fitting with go right in. Same as running the tap for the EGT probe, go too far and the fitting is not going to tighten. The threads should have a taper on them.
Yeah, they must have run the tap too far in. The sensor came be run almost all the way in by hand.
Mine did the same. Then I put in the snubber, and it seems to have cleared that issue.
Originally Posted by rock crawler
(Post 2323809)
Nothing special? Just something I can get at Home Depot?
Originally Posted by 53 willys
(Post 2322982)
what ever you can find to make a clean connection should work...mine was a male to female adapter...
http://www.flybc.ca/forum/style_emot...nworthless.gif
... mine didn't feel right when I put it in either... |
There is a joke there somewhere.
Originally Posted by Fisherguy
(Post 2324662)
... mine didn't feel right when I put it in either... hahaha http://i81.photobucket.com/albums/j2...ax/adapter.jpg
Originally Posted by Howling
(Post 2324666)
ho ho ho
Thanks Mark. Mine never really got 'tight', felt like something got stripped but it didn't leak so I never touched it and kinda forgot about it. |
