Quadzilla X2
hi guys
anybody have installed this item with rail gauges? thanks chris |
I have the x2 race with the commander and fp + rp kit.
I like the set-up, but am on a waiting list for a heavy duty fp sending unit from Quadzilla. My fp jumping all over the place - Justin from Q'zilla said it was the fp sender - give them a call and see if they will send you the kit with the upgraded sender. Great product and service |
All of the adjustable ones come with a built in rail gauge.
hi qzilla
if plug and play? the rail gauges? i have order the x 2 adj. on dtr shop yesterday. chris |
Originally Posted by chrigu
(Post 1891596)
hi qzilla
Yes it is it take place of the old rotorey nob that adjust power. If you put the x2 in by pass the rail preasure will not read it needs the x2 for that. I found that out the other day.
hi guys
i have installed x2 answome power with smarty!!! but the rail pressure jump around on idle from 4800 to 5600! if this normal? i jump also wen i drive. best regards chris |
anybody can help me?
At idle my RP is about 6700 and jumps +- 200.
Driving down the highway it bounces a little but not bad. Remember you are seeing the real time reading not an average. |
but mine jump more than +- 200
Mine jumps a bit but I don't really worry about it b/c when I'm in a good pull up a mountain at 75mph it's reading 27,500+or- 200. And that's when I really care about my pressure. So, I think you're just worrying too much about the little stuff.
