QuadZilla Commander or Scout for Xzillaraider II?
Old Feb 19, 2009 | 04:32 PM
mhenry79's Avatar
Question QuadZilla Commander or Scout for Xzillaraider II?
I have an 06 with the Xzillaraider II 100hp box (QZXZ2003) and didn't want the Commander at the time. Since the box performed so well, this forced me to buy an AFE Stage 2 intake, Blade Runner, and turbo-back exhaust... So now I want to monitor EGT and tranny temp, and add a turbo timer when it becomes available. I want to stick with QuadZilla's electronics.
Would I be better off going back and ordering a Commander, or going with the Scout? Does either option offer defueling or lowering the XZ II's power level setting based on EGT?
Also, if I didn't bother to remove the bypass plug while installing the XZ II, and tore it up, how would I get another one?
Thanks in advance!
Old Feb 19, 2009 | 11:57 PM
OlRed's Avatar
I do not think they make the commander anymore. I am pretty sure the Scout took its place. Not sure about the defuel questions.
Old Feb 20, 2009 | 05:23 AM
tesla440's Avatar
OlRed is right that they have stopped making the Commander. But I'm sure you'll still find some dealers that carry it. From what I know the command will defuel based upon a couple different settings.
But as for as the Scout, I just thought that was a gauge set and that it would not control anything.
Old Feb 20, 2009 | 03:07 PM
fl dodge's Avatar
i have been trying to find a dealer that still has commanders for sale no luck all the new ones are gone ,quad. stopped making them at the end of the year ,also if you go with a scout better check on trans. temp.monitoring some years of trucks its not availiable. There are lots of used commanders on any of the classifieds.With a scout it will just plug into your obd port so your x2 and your scout will be basically two seperate systems
Old Feb 21, 2009 | 08:12 AM
iweb's Avatar
If the Scout plugs into the obd port how would you be able to check egt's? I have a Commander and had to drill a hole in my manifold for the pyro.
Old Feb 21, 2009 | 09:06 AM
Joe Reitman's Avatar
Scout supposed to be able to accomodate EGT sensor...
Old Feb 21, 2009 | 03:01 PM
fl dodge's Avatar
that would be an excellent question for quadzilla their web-site mentions an egt kit available
Old Feb 24, 2009 | 06:34 PM
mhenry79's Avatar
Thank you all for the replies! I talked to QZ and ended up ordering a XZ-II/Commander combo (guess they have it on the shelf), and then I will RMA the existing XZ-II box.
Hopefully the AFE exhaust is in this weekend! Blade runner is another 2 weeks out.
Sixpack73
Sep 22, 2010 07:37 PM
Dane Bramage
63
Jul 5, 2010 04:36 PM
norcaljr
13
Aug 5, 2008 10:13 AM
airforceivan
24
Nov 25, 2007 10:11 AM
stock03
Nov 9, 2006 11:27 PM
