Quad XZT Problem!
Old Nov 2, 2005 | 10:59 PM
codythom's Avatar
Quad XZT Problem!
Well I got my XZT in the mail today and tried installing it tonight, but I ran into some problems. I got everything plugged in, and when I started the truck, it started to idle really rough like it was going to die. Then I took it all off and now when I start my truck it has a check engine light that comes on. Any ideas on what to do? Truck is a 2005 RAM3500. Thanks for the help.
Old Nov 3, 2005 | 05:43 AM
qzilla's Avatar
First, did you check the blink sequence of your LED before you started your truck? This will start us in the right direction of troubleshooting.
Did you check the LED after the truck was running to see if it had a fault?
It sounds as if one of the rail pressure sensor plugs was plugged in backwards. The sypmtom you describe is usually a telltale sing of this.
You can check your codes by turning the key on and off 4 or 5 times fairly quickly. The codes will show up as P0XXX in the odometer window. This will also help troubleshoot your problem.
Get us this info and we can tell you where to go from here.
Quad
Old Nov 3, 2005 | 05:44 PM
codythom's Avatar
It comes up as a camshaft sensor code. My LED blinks green, orange, orange, green. Then when the truck is turned on it looks red.
sCreamin400
Nov 2, 2008 01:46 PM
prkiller
Sep 25, 2007 01:18 PM
Sixpack73
Mar 15, 2007 02:10 PM
hllbllyhellion
24
Aug 11, 2006 07:46 PM
donhov
Aug 1, 2005 07:59 PM
