Quad Race Box?
Old Aug 27, 2006 | 04:31 PM
tdm's Avatar
tdm
Quad Race Box?
I got my Race Box installed this morning (very easy install) and went out to play with it. WOW, how much fun is that
I think that the 100HP setting is just about right for playing around, 140HP really heats up fast. I'll stay away from that setting till I have the intake and exhaust done.
One thing that I noticed right away was the increase in boost. I'm going to need to replace my boost gauge as I have no problem pegging it at 35 pounds. Luckily I have a 60 pounder sitting on the bench already so I'll make that swap tonight.
Question: I noticed that when I set the rotary dial back to stock I still have increaesd boost but stock fuel flow. Is this normal?? I thought that stock meant stock??
Old Aug 27, 2006 | 04:56 PM
973604x4's Avatar
sounds like it is still boost fooling just has stock fueling. shouldn't hurt anything.
Old Aug 27, 2006 | 07:03 PM
wap's Avatar
wap
You can pull 44lbs with the quad, and yes it is stock fueling with a boost fooler.
Old Aug 27, 2006 | 07:17 PM
tdm's Avatar
tdm
OK, I just wasn't sure if I was seeing an issue or not.
Thanks Guys
Old Aug 27, 2006 | 08:24 PM
badcompany's Avatar
Don’t mean to change the subject but I have a juice/attitude and pull over 40 pis of boost a lot. I have a 06 3500 6 speed is that bad for the stock turbo. My egt’s don’t go over 1200. Thanks for the info. All
Old Aug 27, 2006 | 08:44 PM
973604x4's Avatar
nope not a problem....i run mine in the 45-48psi range a lot.
Old Aug 27, 2006 | 09:30 PM
texaspower19's Avatar
HOW ARE U RUNNING THAT HIGH WITH JUST BD, I THOUGHT IT DIDNT HAVE BOOST FOOLING
Old Aug 27, 2006 | 09:35 PM
973604x4's Avatar
I have a Quadzilla beta version Boost Fooler
Old Aug 27, 2006 | 09:41 PM
ok sonds great
v8440's Avatar
Sheesh, I didn't think the turbo on the CR was good for boost approaching 50 psi. I run my turbo up to 45 psi, which seems to be fueling limited rather than wastegate limited.
Old Aug 29, 2006 | 10:35 PM
dodgezilla04's Avatar
i ran my stocker for about 17k miles at over 40 psi, didnt seem to have any problems other than egt's. until I swapped it for a sps 62/14. then I checked the axial and radial play in the stock turbo. uh, I have seen turbos at work get replaced with less wear due to wheel rubbing on the housing. I wouldnt recommend abusing the factory holset for too long. just a matter of time before it becomes a grenade.
Old Aug 30, 2006 | 09:52 AM
yelloz28's Avatar
I wish I could get to 40
BigJohnston
Feb 7, 2008 06:14 AM
coobie
Oct 17, 2005 10:53 AM
wap
Sep 10, 2005 07:15 PM
BigBlueDodge
Jul 25, 2005 01:44 AM
B Proctor
May 16, 2005 08:35 PM
