Quad Boost Fooler ?
what exactly does this product do, and could i benefit from it at all with my mods. i hear people say its the best 70 bucks spent. is it worth it. thanks
Are you seeing overboost codes? If not I would guess that your box does boost fooling. If you are seeing boost codes then you absolutely would benefit from it.
havent thrown any codes at all with the twins.im using the smarty tnt, edge is for gauges.
Ive never had an edge product but I believe the one you have does boost fooling. So no need to spend the extra cash.You would know if you needed it cause anytime you hit 40+ lbs you would get that great ding sound and CEL.
The Juice does boost fool(not sure up to how much), and the Smarty will boost fool up to 44 lbs of boost. The Juice will not let you see the actual boost from twins(it reads off the MAP sensor) since it only reads up to the ECM max which is 44 lbs.
