put a 04.5 turbo on a 03(wastegate???)
i have read sevral places that guys are putting 04.5 turbos on 03s. they all say the wastegate needs moded, but none tell the mod??? i may can pick one up on the cheep and think it would be a good work truck mod, maby reduce egt slightly also. any ideas on the correct mod to the wastegate?
thsnks
Mopar builds it
Cummins SHAKES it
PS ANYBODY GOT A 04.5 USED TURBO ON THE CHEEP???
thsnks
Mopar builds it
Cummins SHAKES it
I am attaching a TST manual that shows how to modify the turbo so you can adjust the boost manually using a boost source.
You will need the boost bolt that goes on the intake.. Genos Garage has them and most likely has the tubing you need also.
Small brass elbow that goes at the turbo end, I am not sure if Genos has? I got mine with my TST many years ago. I have heard others get them, of all places on eBay...
Good Luck.. It is a decent turbo and I would think you can get 400hp safely..
I ran mine at 38lbs of boost (399hp/830tq)using TST for a couple of years without any trouble before I upgraded to the Silver 62.
Here is a source for an adjustable elbow. You can drill & tap the compressor housing & screw this in.
http://cgi.ebay.com/ebaymotors/DODGE...QQcmdZViewItem
You can drill and tap the compressor housing for 1/8" NPT (close to the outlet allows you to make sure the hole get's deburred) and screw the 03-04 boost elbow in to get your boost reference. If the electronic solenoid is still in the 04.5 and up turbo you can either weld the outlet closed or drill and tap it to plug it off.
barngal6
Jul 5, 2009 06:49 PM
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
