Proper normal fuel pressure range
On my 2006 ram, what should I be expecting for lift and rail pressures? I.e idle and WOT...
I believe 8-10psi is the normal for stock oem pumps. Rail pressure you should see
5k-8k at idle 12k-18k normal driving 24.5-26k wot. You don't wanna see any more than that. Or you'll be putting a new release valve in over some time. |
Originally Posted by rip 112
(Post 2760797)
You may be draining the rail. Do you have a lift pump upgrade??? And have you been keeping up on your filters???
