-   3rd Gen High Performance and Accessories (5.9L Only) (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/)
-   -   Which Programmer (https://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-5-9l-only-107/programmer-126170/)
DODGE4X4 Dec 2, 2006 09:24 AM
Which Programmer
Which Programmer will let me turn on the high idel, adjust tire size, horse power, ect...?
Booger Dec 2, 2006 10:18 AM
BullyDog will let you turn on high idle but I don't think it will work on the 6spd. Edge/Attitude will adjust for tire size. I have used both and both make great power. The Edge is not a programmer, it mounts under the hood.
Speed Shift Dec 2, 2006 10:40 AM
The Smarty will do what you want, but you are going to need a clutch, and a fuel system if you plan on useing more than #3. The 6 speed can be fixed for high idel with a wire to the ECM. I have it done on mine.
I noticed you are from Poteet, I am from Somerset, you have probly seen some of my toys around....
Luvnacumns Dec 2, 2006 03:59 PM
The Bullydog with the outlook will adjust for your tires but the Tripledog alone won't adjust tires but it will do the ideling adjustment.
Shane
