problem with quad commander
I have a quadzilla commander and it no longer reads boost. It reads 0 psi almost all the time and some times it will flash a value other than that for a split second. Has anyone else seen this happen? will they warranty it? The commander is installed on a 03 model.
You may want to go to the Quadzilla website and download the latest USB update for the Commander. I recently spoke with Quads technical services representative regarding an issue with accuracy. The representative recommended that I download the latest update directly to the Commander unit in order to resolve the issue. After doing so,the unit has performed flawlessly.
They'll help you fix it. Give them a call.
Thanks guys. I will call them tomarrow.
