PPE & dr Predator WOW!
Well I have been running thhe ppe for awile now onn the 155 program because it stays under 1k for the most part evenn when towing. But i got a mp8 from Wade over at NGM but i havennt really played with it yet because my rail gauge hasnt come in yet. anyway i happened to pick up a dr performance 110 box for a hundredd bucks just to give it a try, holly crap was the test drive fun not only do thhey stack great but if you likke smoke thhere it is. now i know why Mike Drever runs them i really liked my diablo stack bbut i think im going to stick with PPE and i havent evenn tried thhe 210 proggramm yet........needs the trans first trust me
PPE Hot and Dr P stage three is a great setup. I am running it on the 155 PPE setting and the 55 hp Dr P.
I towed my 5ver 37' at this setting and never went over 1250 when running the hills with a strong head wind. Can you say surprised at the power and ease that the truck ran.
U joint were border line when I left but when i stopped they were toast.
Cant wait to get injectors and another turbo.
The cool thing about Dr. P is that once you upgrade your injectors and turbo, you can send you module back to them and they will change the tune to fit your application. Way cool.
I didn't realize how good they were stacked. We use a Diablo with our Dr. P.
Bully dog outlook intake and exhaust GDP walbro comp kit. banks IC HTT ss62,soon to be sled puller 66. PPE drogramer mp8/dr predator stage2 cp3trailmaster 41/2 lift 315mtz centerlines pleny of gauges and so on
973604x4 how do you like suff im thinking of going with there stage3cp3 and injectors
O and yes wade has been a great help i have goten alot of parts from him with zero problems and soon to order my bilt hts great guy
Good stuff. With a stock exhaust and a cheezy intake, my truck dynoed 580 to the ground with his rail, cp3, and injectors...silverbullet ofcourse. Since then I have added a AFE stage 2 and 5" exhaust...big time SOTP difference.
I would expect both your numbers to be a little higher with the PPE Hot and all those mods. Mine is pushing close to 600 with a stock rail, stock CP3, 50hp smaller sticks, and just a Smarty.
I see in you sig that the PPE is also causing high rail pressure. Guess it wasn't the Smarty 4.4 causing it afterall. Sounds like a CP3 issue if you can't run any programming without excessive rail pressure.
Phil doesn't
Sorry Phil, couldn't resist a little friendly ribbing there.
