Power lost -connected to smarty
The other day I started a thread on low boost and power lost, we thought I had a leak some where in the system,returned the truck back to stock and it runs great.When we plugged the smarty in to retrn to stk sw-7 appeared.
Not sure why my computer or truck went into a limp mode and change the power out put on this level,Yes when we re load Sw-7 back up the truck goes into limp mode again. the smarty setting has been on the truck for over 3-months on the same setting, what your thought here \?? |
What codes do you have? If its going into limp mode there is a fault somewhere. My guess would be overboost but that is a vague assumption based on past experiences. The only way to know 100% is to pull the code and report back here.
Originally Posted by matego
(Post 2318432)
Is that the only level? Have you tried sw5 again or sw9?
Originally Posted by rip 112
(Post 2318475)
Just wanted to know if anyone else has experienced this problem ?? |
Weird. I know I had a Bully that did not like to adjust power levels. I have never heard of a Smarty doing that. I thought by derating you meant it would cut power when driving down the road, not accepting the Smarty program.
I would reload the current software on the Smarty and then reload sw 7 into the truck. See what that does.
