Powdered, De badged, Rollin on 37s
I have been runnin the black powdercoated h2's for about a year now. I just put caps on two days ago. To be honest i liked it better without the caps. MOre rugged looking................
Thinking that is how I will leave mine. I do need to touch up the paint on the hubs. That and powder coat the nuts again, well the second set.
Originally Posted by nriver
Finally got a bunch of stuff done
Powder Coated wheels, Mirror Black
BFG 37 12.5x 17 tires
De Badged
Canopy back on, off the 99 CTD
Front 3/4 View
Front Wheel
Rear Wheel
Rear 3/4
I just need to get that bumper done now.
I just like that picture
Enjoy
Getting it dirty tomorrow
Pics, more in the gallery
De Badged
Front 3/4 View
Front Wheel
Rear Wheel
Rear 3/4
Enjoy
WOW WOW AWESOME What size lift? do the tires rub at all?
Lorenz Suspension, 3" IR Coils, SwayAway 2.5" shocks
As for rub, I get a little fender contact on the passenger lower fender. The contact is only with 3/4 of a turn and hitting bumps. Think that may be a bit of a alignment issue. No contact on the drivers side, the passenger looks like it is set back a bit. Either way I plan on making some room on both sides for the tires. It has been to hot to be outside and put the suspension through its paces. I plan on cycling the suspension through the entire arc and turning radius and adjust the lower fender corner to make enough room. Thinking it is just a 1/2" adjustment, the lower fender should be able to take it. Just a little nudge.
The tires also hit the control arms at full lock. I will just limit the steering. I may also get my H2 wheels done and see how that changes the control arm contact. I should do them any way, get them powdercoated with the rear bumper.
Thanks for all the nice coomplements.
Originally Posted by scoutman
I love the blacked out look! How much did it run you to have the wheels powdercoated? Sweet Rig!
Scoutman, I had mine done too. Locally, I paid $80 to have all 4 wheels sandblasted and $100 to have them powdercoated black. Also, I spent another $48 having the tires swapped over to the powdercoated wheels and rebalanced/mounted etc. Pretty reasonable imo.
my wheels were a bit less than that, but in the range. 200-250 for the project.
I bought a second set of wheels to keep the truck on the road during the powdercoating time.
One think I learned you need to remove the powdercoating on the hub mouting area. It is a tight fit and the powder can shrink a already tight gap. I need to pull mine to do that some more. I dont want to be stuck taking them off and have them painted together. I will also remove the paint from the lug nut seats (lack of a better term) to get better contact. Also to not chip and remove the powder...
Thanks
Thanks
Just re-read 4x4nots post. The shocks are a 10" travel 2.5" Diamater Remote Reservoir shocks. They are a bit longer than stock. I dont recall if they are 2.5" longer. But any way.
The suspenion is from Lorenz. He has a few options on suspensions now.
http://lorenzindustries.com/
Originally Posted by cquestad
My truck must be sneaking out on me at night and getting around...
It seems to be a lot of little offspring popping up all over the place!
nice truck
