PMT low end power
Old Aug 27, 2008 | 07:29 PM
sentzible's Avatar
PMT low end power
Have PMT with HV 2.2 SV 1.00.9 Programed. I think it is the cl program. Downloading the program I never get the low end power option? Do I need to download a new program # if so what # is strongest for 05.Also banks 6 gun is off need to update my sig. Thanks ED
Old Aug 27, 2008 | 07:45 PM
chipmonk's Avatar
don't know about the PMT, but on my TD it asks about tq mgmt and low end power (Y or N), and about adjusting the speed limiter and rev limiter prior to the download, while plugged into the truck.
Old Aug 27, 2008 | 08:26 PM
mpracehemi's Avatar
You won't get that low end option 'cuz you have a manual trans.. The PMT most likely realizes that so it won't be offered. I think, not positive.
Old Aug 31, 2008 | 10:50 AM
sentzible's Avatar
Thanks for the replys thats what it was. I was also wondering if anyone has had problems with the pmt making some radio stations static? When i unplug the pmt from the cradle the station becomes clear again.
Old Aug 31, 2008 | 12:03 PM
mpracehemi's Avatar
Where do you have the power source plugged in for the pmt?? Try a diff. fuse if you're jumping, try a spare fuse port or wire up a extra fuse panel especially if you plan on adding any more electrical acc. It's not very good to keep using jumpers from the stock fuse box, could cause an elect. fire. Honestly I was jumping and read someone added a fuse panel (7 circiut from painless) and I use on my race car, why didn't I think of using it on the truck. I was keeping the 2 seperate both diff. worlds but in some areas the same, common sence.
Old Aug 31, 2008 | 12:36 PM
sentzible's Avatar
Thanks for the reply I only have one jumper from fuse #28 to the pmt with no other acc. hooked up to fuse box. Do you know which spare I could use for the pmt only thats switched?
Old Aug 31, 2008 | 02:14 PM
mpracehemi's Avatar
Here's what you do; get your self a light(circuit) tester( under $10) from any auto parts store and check for yourself. This little tool will be useful for a long time. I don't mean to offend you, I don't know how mech. inclined you are. I'm just trying to help. I'm telling you in case you don't know how to use it. All you have to do is ground where the stock ground is on the inner fender drive side by the hood shock. Then stick the probe on one side if the fuse insert and see if the light bulb glows with and with out the key on. When it glows with the key off, DON'T use it, go to the other side of the fuse insert and check, that should be the side to jump from. PM me if you have any trouble of what a tester looks like.
Old Aug 31, 2008 | 03:37 PM
sentzible's Avatar
Thanks, I appreciate the help. I just got done trying all the switched fuses for powering the pmt including the spares that were switched and it still interferes with the radio on certain stations. If i disconect the power to the pmt my the stations come back. Has anyone with the Bully dog pmt had any similar problems?
cali4niacoalrlr
Apr 1, 2014 09:22 AM
city slicker
Oct 24, 2007 10:23 PM
Breck-Ram2500
Jun 2, 2006 07:47 PM
RAMRODD
0
May 23, 2006 10:08 PM
spitzair
Jan 24, 2006 03:42 PM
