pics of my new rims and 35's w/ 2" level...no rubbing!
18x9 Alba's w/ 35x13 grapplers:
5.5" backspacing provided just enough room to clear while turning:
3" BDS trac bar drop bracket:
customized 4" MBRP = no soot on my white paint.
thanks guys. i guess i probably should get the correct size spare tire, that lock came on the truck....havent touched it since i got the truck
the exhaust really does keep all the soot off of the paint, i was just getting tired of trying to keep it clean so i decided to cross my fingers and cut it up. it worked out well....gives it kind of a hidden look.
sure wish i could get my speedo recalibrated to the 35's
Weak spare tire winch=master cable lock fix.
i installed the trac bar drop bracket because w/ the 2" front lift the axle is pulled toward the drivers side noticably and over time components will wear. they dont offer a 2" bracket and i didnt want an adjustable trac bar because of the heim end maintenance so i figured the 3" bracket would correct it for the most part. it actually worked better than i thought because now the axle is centered visually and from every measurement i took. im ver happy w/ it and the alignment went great also. i may add a 3" drop pitman arm next.
Even some programmers allow the user to adjust tire sizes.
Nice looking truck, your White has a real nice shine to it. Good luck keeping it that way.
