Pics of 37s on 4"-4.5" Lifted Trucks......
Hey guys, can I get some pics of trucks that are running 37" tires with
4"-4.5" of lift? THANKS! |
Do you know the specs on the lift? Looks like a 6" kit......
I think it's a 6 too, but not sure. He's out of town till Wednesday... his username is blackbetty, ask him...
37's won't fit under a 4 or 4.5" lift. 37's will rub with a 6".
Really? I figured they would fit since you can run 35s stock, and with a leveling kit easy. I figured with a 4.5" lift, you could get 37s to fit like 35s on stock height
37's fit fine on stock wheels with just a 3" Carli leveling kit. I'm running 37's on mine, but with the Lorenz stuff, you'll have to do minor trimming.
--Eric |
I think if you add some extended length control arms they'd fit fine without any rubbing issues.
I have 37's and 3" kore. only rubs on control arms at full lock. I will post pics tonight when I get home.
any of you guys do allot of towing with your 37s ?
I tow with my 37s almost every day. Pro comp x terrains
Thanks for all the talk guys, buy how about some PICS!!!
Originally Posted by tritont
(Post 2318293)
37s will fit at stock hieght/2" spacer(and rub on hard articulation), and on a 3"-4" lift will fit fine with minimal rubbing. With stock wheels, rub on the control arms at FULL lock, but no where else. And H2s seem to be the ticket for no rubbing(or similar backspacing/width) I ran 37s with a 4" lift with no issues, and Boz is doing the same... |
Originally Posted by D45
(Post 2318537)
I agree, I run 37s with only a 2in leveling kit... my truck is 4x4 btw. Fit/ rubbing issues, all have to do with backspacing and tire width.
