Phedophile Larry ?
Old Jul 11, 2009 | 07:39 AM
huck25's Avatar
Phedophile Larry ?
If this tune is a pressure tune would be able to stack it with my Edge or would that be adding to much of the same thing? Just trying to justify keeping my Edge. I also heard that I might be able to send my Edge back and get it turned into a pressure box is this true? Need more pressure. Thanks for any replies.
Old Jul 11, 2009 | 12:19 PM
huck25's Avatar
bump..................
Old Jul 14, 2009 | 10:40 AM
SMOKIN-U's Avatar
you will need to stack a pressure box with it to keep from throwing a high rail code. i wouldnt stack the juice as there would be way too much timing pl timing rattles enough on its own without the help of anything. do not need to run it up all the way unless you want the extra fuel. enjoy!!
Old Jul 14, 2009 | 03:19 PM
Jason_K's Avatar
has anyone running the pl tune monitored their rp duing daily use? if this tune is a pressure tune, i would be afraid that it would run too high of rp for everyday use.
Old Jul 14, 2009 | 03:36 PM
SMOKIN-U's Avatar
it only runs about 19-22000 during normal driving but i have seen my truck hit anywhere from 26700-27200 at full throttle during a sled pull with it. i have had it on my truck for almost a year now without an issue hasnt even ever thrown a code and i drive it almost daily
Old Jul 14, 2009 | 07:09 PM
Jason_K's Avatar
thanks man, just curious
Old Jul 14, 2009 | 08:28 PM
Nsomniac05's Avatar
So what is the point of putting pressure in a tune so you have an "all in one" box, if you just have to stack it with another box anyways?
Old Jul 15, 2009 | 06:48 AM
huck25's Avatar
Smokinu do you still stack a pressure box with pl or do you run it by itself. Does it have enough pressure to keep up with the fuel that is needed?
Old Jul 15, 2009 | 09:50 AM
SMOKIN-U's Avatar
yes i stack a pressure box and yes it does have enough. i dont know for sure but i think you need to stack to have the pressure box pluggged into the map to fool it. you dont even really need it turned on just plugged in i havent seen any pressure changes with the box turned on as the downloader has good pressure and is generally higher than the pressure box
Old Jul 15, 2009 | 07:06 PM
Nsomniac05's Avatar
so all you need is a boost fooler then?
Old Jul 15, 2009 | 08:10 PM
huck25's Avatar
Thanks for the info I guess I better take out scarry larry and try this because now with the 90 hp tips I seem to drain the rail doing a burnout.
smoky05
22
Nov 30, 2007 08:26 PM
05dodgezilla
0
Nov 22, 2007 08:40 PM
huntingdeer
Sep 17, 2007 09:34 PM
HeberRam
Mar 30, 2007 05:37 PM
Snojumper
34
Mar 18, 2007 12:27 PM
