Overhead gauge mount - opinions
did a search and didn't see a lot of opinions so ---
You guys with the overhead mounts -
How do you like them?
How's readability?
Night glare?
Rearview mirror distraction?
Installation?
edit: oh yah.. what's it look like from outside?
Any gottcha's? Wish you had something else, kinda thing.
Thanks in Adv.
How's readability?
Night glare?
Installation?
Thanks in Adv.
How's readability?
Night glare?
Installation?
this is where I have my attitude and it is where I would put analog gauges if I ran them. I just like the fact you can run all your gauges in one spot even if you want to run 4 of them. The visibility is fine. Then again I am lifted so the pillar is just not an option for me. I like my grab handle.
I got the Autometer dash mount with Stewart Warner guages. Pillar mount I could not see past, and cubby hole I could not see while driving. Overhead was a consideration until I had to install it. Dash mount is just right!
Rick
Rick
Guest
Posts: n/a
I really liked my overhead mount but I couldn't keep the **** thing stuck to the windshield. I don't know why but as soon as I saw 95*+ temps the adhesive would start sliding and then fall off. I tried everything and finally gave up and did the a-pillar. I'd like to try the Attitude mount up there but don't want the same thing happening.
the 3m stuff that came with my attidude is doing fine so far. the attitude is lighter than analog gauges though. the type of mounting adheasive given to you could be an issue though. that could depend on the company supplying the mound. the juice mount is made by edge and comes with a 3m adhesive soltion. it is not a velcro but a plastic velcro like adhesive material. I have not had hot hot days yet though.
I am sure if you called some tech support at a big company they make high temp adhesive materials. IT worried me to start with but so far so good.
Overhead
I have my "less" important gauges in the overhead pod, air pressure for the exhaust brake, fuel pressure, and oil pressure. The real important ones boost and pyrometer are mounted on the steering column. It's not that the overhead gauges are difficult to see it's just I will scan my factory instrument cluster several times more often than the overhead pod. See my photo gallery for my setup. Good luck!
L8r,...........dogger
Xonid,
If the slow down in sales of A pillars vs the increase in sales of overheads is any indication they are very very popular!
The adhesive issue is easy, if you or anyone has ever used any type of armour all in the truck (sometimes the fumes from the plastic in a new truck will do it too), you will have to use a prep solvent or lacquer thinner to clean the glass before you attach the mushroom hook and loop tape. If the glass is clean you won't have any issues with the mount falling off, plus about 70% of the weight is supported by the lip that goes under the headliner anyway.
Mark @ DPPI
Mark @ DPPI
Guest
Posts: n/a
I cleaned the glass with solvent, adhesive remover, goo-b-gone, alcohol, nail polish remover, you name it, I tried it. The glass was CLEAN!!!! I'm not knocking the mount, like I said I liked it. I just couldn't keep it on the window. Also, when I'm out railing around in the desert in 95*-120*, the last thing I need is for my gauges to fall and pinch and break my boost line. A few times my passenger had to hold them on the glass. Once the glass cooled down, no problem.
Thanks for the replies.
Hey Pull U 2 - did you tried duct tape, I hear it can fix anything.... just joking.. you have a good point about bouncing around, I'll consider it.
Sailpipes - looked at your pic from the front, looks like you can't even tell it's there.
thanks guys.
thanks guys.
Guest
Posts: n/a
thanks guys.
thanks guys.
Oh well. I may try the Attitude up there and keep the analogs in the a pillar.
I got my boost and fuel press. guages in the overhead and like it alot,originally I only had the boost guage in the pod and when I had to drop it back down to install the fuel press. guage I had a heck of a time getting it loose,thought the pod was gonna break,so no adhesion problems on mine and that hook and loop holds good to,I have know concerns with it falling down,it has been there for over a year and no problems.
