now i have trans and smarty what else should i get for towing
i tow 10k plus about 80 percent of the time.my truck is the 235hp version and i want it to tow a lot better.what are some good set ups to go with
I'm thinking a turbo or two. If you've got the cash go for twins. You'll be able to run the smarty on higher settings while towing.
Air bags made a big difference for me. No more sagging rear end.
i will have to stick with a single turbo
Originally Posted by marlbroman
(Post 2201148)
If you don't plan on anymore mods a htt 62/65/12, 13ss or 14 would be good. Maybe a 62/71/13 if you want a little more cooling. Nice thing is you can get them from Lary at the DTR store for a decent price. |
One of the best mods I made for towing( 13k) in the mountains is a rear sway bar. I have a short box if you have a dually then you probably ok. check out Al Corr sway bar and air bags.
https://www.dieseltruckresource.com/...light=sway+bar |
Originally Posted by shortbed rv
(Post 2201219)
If you want more usable power a turbo and lift pump is in your near future. Just be very careful what you buy. Twins would be best, but a 62/65/13ss would be good.
(Post 2201128)
Might want to consider a fuel system upgrade also. |
If you get near any mountains an engine brake is a must have!
Im running a HTT 62/14,Smarty,GDP392, and pull a 11k trailer in the mountains not flat ground and have plenty of power. During the summer EGT's can get high on 10% grades but, I still have plenty of power.
i have a pac brake i will add that to my sig.all i do is tow up and down hills.
how bought the super b turbo.that way i can up grade latter.
Originally Posted by trx
(Post 2201139)
| All times are GMT -5. The time now is 10:24 AM. |
