Need Help with programmers
I see some people have had problems with the edge attitude and I also read once this is hooked up it will void your warranty because of the peice you have to drill to put on. Is this true?? If it is then I want to know what chip or programmer can I put on my truck that will not void my warranty or something that the dealership can not trace.. I have a new edge attitude that has been sitting on my counter for about 3 weeks now because I dont want to void my warranty. thanks for all your help. Rob
Just put it on, and when you go in just remove everything but the pyro. Buy your a cheap pyro gauge and if they ask pull it out and tell them U use it when you tow. Or you could always just plug it with a pipe plug. That is what my truck has in it since I removed the commander.
2006 MEGACAB,
You could use a box that doesn't damage the wire harness like the Quad Race box. It uses the factory plugs, "plug N play". Nothing for the dealer to see and gives you up to 130 HP. Easy install.
I love mine!
I love mine!
DieselGoose
Jun 20, 2005 09:08 PM
saint
0
Feb 11, 2005 10:33 PM
hotdram
Jan 31, 2005 06:46 AM
