Need help installing boost gauge
Old Oct 1, 2007 | 10:53 AM
Ernst223's Avatar
I just bought an autometer pillar mount boost and egt gauge assembly. The question i have is, how do you install the boost gauge? There seems to be no where to connect that little hose, i have heard some people talk about installing them with the banjo fitting. What is a banjo fitting and where would i get one? Where is the best place to install the gauge? Intake horn?
Old Oct 1, 2007 | 11:08 AM
t-boe's Avatar
You can get a boost bolt. A number of places carry them. I got mine from Diesel Manor. It installs in the intake manifold by replacing one of the bolts.
04DEEZELRAM's Avatar
I used the boost adapter, it made it really easy to install.
http://www.genosgarage.com/prodinfo....er=RLT-ADAPTER
Old Oct 1, 2007 | 11:19 AM
t-boe's Avatar
That's the boost bolt.
Old Oct 1, 2007 | 11:42 AM
Ernst223's Avatar
How do you attach the plastic hose to the boost bolt?
Old Oct 1, 2007 | 11:46 AM
t-boe's Avatar
It comes with a compression fitting.
Old Oct 1, 2007 | 04:43 PM
TNLoneWolf's Avatar
"Shop DTR", right here on this site. They sell the boost bolt....help support the site.
Old Oct 1, 2007 | 05:10 PM
t-boe's Avatar
Didn't know that. Kudos man!
Old Oct 1, 2007 | 08:00 PM
cbrahs's Avatar
do it for FREE. take your intake horn off, drill and tap and DONE. free and it works. That is how I did mine. XLR8R gave me that tip.
Old Oct 2, 2007 | 07:46 AM
Neight's Avatar
That is how I did mine also you. I was able to use the same tap I bought for the EGT probe.
Old Oct 18, 2007 | 07:04 AM
cb06R1's Avatar
quick question. when replacing the horn back on the manifold, gaskets, where to buy, how much and what part number? and what torque should the bolts be tightened to? TIA doing this this weekend if i can.
Old Oct 18, 2007 | 10:00 AM
rufushusky's Avatar
I don't know the part number off hand but I would think an autozone or something like that would have those gaskets...they should be fairly economical.
Old Oct 18, 2007 | 10:34 AM
cbrahs's Avatar
make sure they are METALIC based gaskets or you will get a check engine light the grid heater is grounded thru the gaskets.. I bought mine from dodge for like $3.50 each.
Old Oct 18, 2007 | 12:25 PM
crownsey54's Avatar
i did not even get a new gasket is that bad?
Old Oct 19, 2007 | 12:05 PM
cb06R1's Avatar
well, i got it all installed ... took FOREVER! two trips later into town ... first mistake, i kinked the plastic line it came with. so there's a trip into town for fittings and air line .. well they didnt have any vacuum line so im using fuel line, no biggy ... well im 2" short! so there's another trip, thankfully i tried mounting my gauge into the pod w/ the fittings i had, and i was bottoming out, so i needed to buy two 90º bends. thankfully i know the manager at Advance Auto and got 5 fittings and 15 foot of fuel line for $5 LOL. now i know im makin 20 sometimes 21 psi of boost.
ALSO when i took off the intake horn, i loosened the 4 bolts and then loosened the clamp on the IC piping and the horn just kinda fell off of the intake heater, so im not sure if it was loose or not? i torqued it down to 20ft/lbs will that be enough? also, i wasn't sure if i should loc-tite them or just keep an eye on the bolts? Thanks for the help guys, i really do appriciate it!
now im off to do the egt gauge .. woot!!
