Need help
Need help
Hey guys I need some help on a 06 Dodge Ram 3500 5.9. When it is under a load it will shoot antifreeze out the overflow bottle. Any ideas other than a head gasket what could cause this? Any help would certainly be appreciated.
DTR 1st Sergeant
Headgasket or some loose head bolts...
Not too many areas to look at. If it happens when you get some boost going, then there you go. Either you are lifting the head or the gasket is unserviceable; either way you are pressurizing the coolant system.
smokin24v
03-18-2008 01:21 AM
pwrtripls1
02-08-2008 07:25 PM
spooling
09-13-2007 10:05 PM
