With my supporting mods can I run SMARTY #9?
Alright over the next few days I'm having a GFS 392 installed as well as a Southbend Con OFE . With those mods and the ones in my sig, can I safely run Smarty#9? What level should I tow with?
Originally Posted by spooling
(Post 2012568)
depends on which program you run
well I still have the stock programming in my Smarty, should I switch to another version?
I've run smarty 9 with my mods...but mostly beta 4.4 level 7 and now tnt level 7....while i want an aftermarket turbo (on the list), egt's arent really a problem if you're not doing 1/4 mile runs with the throttle burried....i actually never really see over 1250*...but i'm not towing, just street driving....
I dont see a clutch in your sig???
Sw9 on my stock clutch is very slippery.... |
in my first post I stated that I'm having a southbend ofe installed as we speak and Glacier fuel system. Already destroyed my clutch towing on #5. Suppose I can update my sig now too! :D
I run mine on 9 all the time with the 4.01 version and it get HOT, really HOT at WOT, I have never went on the track or dyno since installing it. I can get to 1500+ by the time I get to 85-90 MPH. I think that you should be fine, mine holds it just gets hot when I play.
(Post 2013436)
Originally Posted by omaharam
(Post 2012580)
Should be good, just keep an eye on those egts with a stock turbo.
As others have pointed out you will be fine, get ready to feel more power once the new Walbro is in!!!!!! [guitar] OMAHA is right watch your EGT's but I have never seen EGT's (without towing) over 1300 and most the time I run my JUICE in HOT mode also!!!!!!!!!! Mike, Thats a great point but you know that the SMARTY runs about the coolest EGT's for a programmer/box/etc on the market [coffee] |
another question thats been asked a million times...What do you think she'll dyno at? Whats best mode to tow on? What should I do for my next mod?
My wifes dodge did 450 on maddogs dyno last month with a smarty on no9 and a stock clutch thats no hold any more
