my predator wont reinstall!!!!
i took my diablo predator off the other day to take my truck to the dealer to run a injector check, and when i went to reinstall it yesterday, it goes as far as installing the programming, thru the %'s and all. but then says something, like "programmer not for this vehicle" or something like that... what could it be? could of they reflashed the ECM and the predator need uploaded now?
You 100% sure you put it back to stock settings????
Mine did that once but I just hit the middle key and it finished just like it is supposed to...
I would try updating it before I tried again.
I had a situation like that with my Superchips. I had to send it back to them (California to Florida, of course). They said the ABS brakes did something funny or something. If you have to, at least you are not crazy far from Boca Raton.
Good luck buddy. |
yeah, i had it set back to "orignal backup" then when i went to install the "performance" tune again, it said this. i will try it again tonight and see what it does this time. if it does it again, i will call Diablosport and see whats up....
well i went and tried it again, it said that the last install was not completed, so it completed it, and now says the "performace" tune is installed.... so, hopefully good from here on....thanks
