More BullyDog drama
Old Jan 20, 2007 | 03:34 PM
cooker's Avatar
More BullyDog drama
So i removed the program from the truck about a week ago because I has a code that TripleDog would not clear, Now that its off that code is gone, but now I have 2 codes a P0514 and a P0633. This truck has never had any codes before, When I check the codes with the TripleDog and the program not installed I only get one of the codes and it will not clear it, but when I do the 3 key cycle both of these codes pop up. So the main question here is what do these codes mean and how can I get rid of them???
Old Jan 20, 2007 | 03:43 PM
rustyshakelford's Avatar
the 0541 one is just a battery temp one...no big deal, i dont know what the other is
brett
Old Jan 20, 2007 | 03:55 PM
cooker's Avatar
Why wont the TripleDog erase it? I have a buddy with a sanp on scanner, maybe he can clear them. I searched this site and cant seem to find a code list with these codes on it.
Old Jan 20, 2007 | 04:08 PM
derek.mckay's Avatar
Don't know why it won't erase it, but according to the Dodge trouble codes, P0633 is SKIM key not programmed in PCM...doesn't sounds like a biggy to me?
Derek
Old Jan 20, 2007 | 04:14 PM
cooker's Avatar
what is a SKIM key, and can you post a link to where you found these code? If i disconnect the battery for 10 min or so do you think it will clear them? THANKS FOR THE INPUT
Old Jan 20, 2007 | 04:51 PM
Luvnacumns's Avatar
I had the 0541 code all the time on my 05 no biggie don't know about the other one..
Shane
Old Jan 20, 2007 | 05:10 PM
As far as I know the SKIM key is the sentry key...the one that activates and de-activates your alarm system...did you have the dealership program it...if so, does it still activate and de-activate your security system correctly? If not, that may be why you're getting this code. Unplugging your negative battery terminals for a bit then plugging them back in will reset your system, but if I am correct, it will take 3 successful starts, warm ups and shut downs before the computer will actually clear the codes if it checks out that everything is really ok and it just received a glitch.
Derek
Rafter B
Jan 13, 2013 10:43 PM
lenuelmp23
Jun 15, 2010 02:13 PM
LilBigd02
17
Feb 28, 2010 09:22 AM
HMartin
Jan 11, 2006 10:07 PM
B1 Power Wagon
Dec 16, 2005 07:40 AM
