Low Stall TC, Pros Cons
Old Dec 15, 2007 | 03:56 PM
RDR's Avatar
RDR
When do you want a Low Stall Torque Converter and when do you not?
What are the pros and cons of having one?
Old Dec 16, 2007 | 08:37 AM
XLR8R's Avatar
You want a low-stall converter if your engine gets up on the powerband relatively fast - like a CTD with lots of grunt down low.
High-stall to allow the engine speed to flash up into it's powerband before significant fluid coupling occurs - like a gasser.
Powerband matching aside, TCs are analogous to flywheels on a manual for launching purposes... heavier vehicle needs a heavier flywheel/higher stall converter, etc.
Also, TC lockup is important for better fuel economy and lower tranny wear.
Old Dec 16, 2007 | 09:30 AM
chrleb1's Avatar
Low stall converters work great on a stock truck or with a stock turbo. Run a big turbo.... you'll get killed off the line.
Old Dec 16, 2007 | 12:15 PM
jgiachino's Avatar
Even on a stock turbo, i can notice my DTT prevents spooling a touch vs stock trans...at least that's what i think it is....if i just mash the pedal from a stop, i get lot's of smoke and a 1 second pause....then off like a scalded dog....
Old Dec 16, 2007 | 12:49 PM
CTDowerTN's Avatar
mine is the same way, if i stomp it from a dead stop, it rolls out a cloud like crazy, then all he** breaks loose!!!
flyingd
17
Jul 11, 2017 11:13 AM
JD730
Aug 2, 2005 11:33 AM
steelsoldiers
48
Feb 3, 2003 11:10 AM
mdq
Jan 16, 2003 04:59 PM
