Lorenz suspension and wheels/tires questions...Help
Old May 6, 2007 | 07:22 PM
The_Mexican's Avatar
I just bought a moto metal's wheel set, wheel size is 20x10 with a -12mm offset.
I also have put the bushwacker extend-a-fender flares and a 2.5" daystar leveling kit for now, but I'm about to buy a Lorenz 2.25 SAW kit.
My questoin is about wheel/tire fitment, I tried to put some nitto terra grappler's 325/60/20, I knew the tires were gonna rub even with the 2.5" leveling kit but not THAT much so I tried them anyways and a piece of the truck's running board and one fender flare took a dump.
Since the the Lorenz kit raises the truck 3" I'm almost sure that the 325s won't fit either so now I'm thinking 305/55/20.
I also thought about the fabtech or skyjacker systems that have bigger lift kits and keep the 325/60/20 wheels but I really was sold on the functionality and looks of the Lorenz suspension.
So my questions are:
Will the 325s nitto's fit with the Lorenz Kit?
If not, will the 305/55/20 tires fit ok or is it gonna rub anyways with the Lorenz kit?
Any other suspension recomendations?
Please help.
Thanks in advance.
Old May 6, 2007 | 07:27 PM
Danderson's Avatar
Fittment
Please help.
Thanks in advance.
www.thecarlisuspension.com He's got some slightly longer control arms that would push the wheels forward 1/2". Kore's got some too but their pricey. e-mail Sean with your question and ph# and he should contact you within 24hrs.
Old May 6, 2007 | 07:49 PM
CDoskocil9's Avatar
Actually Kores Chase series arms are cheaper not better but cheaper.......... You could just buy the Lorenz then add new arms KORE, Thuren Radius Arms , or Carli...............
Old May 6, 2007 | 10:54 PM
Thanks for the replies guys.
What about the tire size, which should I use?
Old May 6, 2007 | 11:37 PM
Marek Robinson's Avatar
Muted User
What backspacing do those wheels have?
You are probably going to have some rubbing issues.
Old May 7, 2007 | 12:09 AM
Boz007's Avatar
Get rid of the wheels. Find one thats 20x8.5-9 with 5.5-6" of backspacing and you'll fit those tires. The wheels are you're problem.
Old May 7, 2007 | 08:20 AM
nriver's Avatar
like others have said
The wheels are the problem.
Your tire size is only a ~35x12.5x20. Not a big deal for a leveling kit or Lorenz suspension.
Dont think the control arms will help all that much either, but I have not tried them.
Most people use a 8 or 8.5" wheel with 5.5 to 6" of backspace
The 2.25 Lorenz kit is suppose to Rock!
Old May 7, 2007 | 01:09 PM
cquestad's Avatar
wheels...another vote for trying to USE THE WAY WRONG RIM!
Old May 7, 2007 | 05:21 PM
Lsufan78's Avatar
with that small of a lift and those wheels, you'll be lucky to clear 33's without rubbing. i can't clear my 37's on 7"s of lift with the same wheel type, except mine are 17's. that's soon to be fixed though!!
Old May 7, 2007 | 05:38 PM
BlackSunShyne's Avatar
Boz nailed it. It is the wheel, the moto Metals are not the ideal backspacing, especially with a 10" wide wheel.
Old May 7, 2007 | 05:51 PM
mipapa's Avatar
I've got the Lorenz Bilstien kit and I have minimal rub with 325/60/20's. My wheels are 8.5 x 20 Welds with a 5.5 inches of backspace. It's the wheels that are your problem.
mtnman006
24
Sep 8, 2009 03:14 PM
1320
May 29, 2009 10:24 PM
Buffalo
Sep 25, 2007 08:24 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
Gary C
27
Mar 11, 2004 07:42 PM
