leveling kit install tips inside
When I was reading up on how to install my Lorenz leveling kit, I saw a lot of guys either using coil spring compressors or removing the track bar bolt. Neither of which is very fun, getting the track bar bolt threaded back onto its hidden nut is something I never want to do again. The driver side spring goes back in easily if you unbolt the sway bar, not the case with the passenger side.
Try this: get a small bottle jack (I used a Craftsman 6 ton) and put it in between the frame and the axle on the passenger side, there's a nice flat spot just inside the lower spring mount. Jack the axle and frame apart and the spring slides right in. Slide the shock tower mounting bolt ring inside the base on the frame with the shock installed in the tower and finger tighten all 3 nuts, will hold it in place while you slide the springs back in. Remove the nuts, slip the shock tower onto the bolts and tighten up.
I unleveled my old truck and leveled the new one in a few hours, got it down to a science. Wish I had thought of this the first time. If anyone needs a complete write-up let me know, makes the job go smoother if you've never done one.
thanks man i am going to be trying this for the first time on my 06 when i get stateside next month i got a revtek kit going in i figured jack up one side to compress the spring then lock in compression with a ratchet strap untill i get the spacers in
If you r having to jack the truck & axle apart, what is it that is putting up the fight & are you not bending that part? Seems like you are going to be tweeking something if you have to jack it apart. I'm not saying your doing anything wrong, I'm just curious 'cause I'll be doing this real soon. TIA
alternatively if you have any 350lb friends have them stand on the hub and hold on real good while you throw the spring in there
Easiest way! Take it to a wheel and tire or frontend shop, give'um $150.00 to install them and do the alignment! Go for lunch and a couple of cold ones, return in a couple of hours and it's done!
i did mine at work and it was no fun...i didnt have a spring compressor and had to use the spreaders to compress the spring...
for those that know what a spreader is then you know how dumb that was and for those that dont, its the "jaws of life" that spreads instead of cuts...
brett
brett
how'd you get the bolt back in? took 3 mechanics and a new bolt at the dealership. it wouldn't have killed Dodge to have welded the nut behind the axle.
