Leveling Kit COILS no spacers.
Old Jan 10, 2007 | 01:19 PM
ROOFGOOF's Avatar
Hola,
Looking for some reports on who has done the upgrade with front COILS to level out their 3500's.
I have a 2007 Mega and want to swap out the coils... just not sure what manufacturer (if any) and looking for recommendations. Cheers!
ThanX !!!
Tim
Old Jan 10, 2007 | 03:38 PM
Speed Shift's Avatar
Skyjacker has a kit w/2" coils, lower control arms, and bump stops $470. I thought that was a little ridiculous, for the parts it comes with...
Old Jan 10, 2007 | 04:44 PM
ptgarcia's Avatar
I leveled the front of mine with coils. Couldn't be happier. I got everything from Don Thuren at Thuren Fabrication.
Old Jan 10, 2007 | 05:03 PM
ROOFGOOF's Avatar
I'll check them out... I forget who the manufacture was , but there was a company that had larger coils to level it out, but the coils were red in color...
Old Jan 10, 2007 | 10:12 PM
Howling's Avatar
Skyjacker has red coils
Old Jan 10, 2007 | 10:15 PM
T-REX's Avatar
kore suspension is good
Old Jan 10, 2007 | 10:56 PM
ptgarcia's Avatar
But Thuren and Carli are better...
Old Jan 10, 2007 | 11:56 PM
one54ton's Avatar
^^^true^^^
Old Jan 11, 2007 | 07:47 PM
spankdog's Avatar
Just curious, why is Thuren and Carli better than Kore??
Old Jan 11, 2007 | 09:28 PM
75bronco's Avatar
i did't think thuren and carli had a variable rate spring like KORE
Old Jan 11, 2007 | 09:36 PM
onesloryd's Avatar
The KORE VR springs are only available with higher end kits and the VR springs they are currently sell are already into the second rate when installed. I pretty sure you would be happier with Thuren or Carli springs
Old Jan 11, 2007 | 09:37 PM
T-REX's Avatar
KORE is the best
Old Jan 11, 2007 | 10:37 PM
Danderson's Avatar
Lorenz.
Consider Lorenz too. Knowledgable guy. Good service. He saved my Kore system application with my popup cabover with a custom revalving. Took all of 1 hour for both Bilstein 7100's.
Old Jan 11, 2007 | 10:43 PM
ptgarcia's Avatar
KOREs variable rate springs are too stiff and their shock valving is too soft.
Old Jan 11, 2007 | 10:50 PM
CD in NM's Avatar
I have the KORE HD Leveling, am very pleased with it. Mine came with the Bilstein shocks, now I believe the kits come with the Fox shocks. When I bought my kit, I was told that the springs ARE variable rate. I also installed the Bilstein shocks on the rear. The steering dampner is a single Fox unit.
Carli, Lorentz, and Thuren have excellent products as well. Their products were not available, or just becoming available when I got the KORE stuff. All of these will serve you well. My buddy bought the skyjacker springs and shocks for his Dodge 3500 when I got my system. He has since switched to the KORE and Bilsteins since driving my truck. I am sure that I could improve things with an aftermarket track bar as many have done, and probably some other things as well. I imagine over time there will be lots of stuff that will be of benefit to our suspension systems.
CD
