Just got my Scotty's Air Ram - Disappointed
Originally posted by Lightman
I really like the fact that it draws COLD air from two locations, and doesn't draw in warm engine air like a bhaf or other intake.
Originally posted by Don M
Now if the cat hunting law would pass in Wisconsin my world would be perfect.
I told the wife tonight I might have found my calling...hunting cats in the wilds of Wisconsin for the betterment and safety of mankind!
Don~ [/B]
Don~ [/B]
Theres a cone that the filter sits in that is placed inside the housing.
I call it a 'cone' because it is shaped and tapered just like a cone to shape air around the filter as opposed to air slamming into the flat end of the filter.
Its an integral part of the assembly. I am certain you would know if you did not have it.
email me and I can send you the assembly instructions that display it.
info@scottyairsystems.com
Another very good feature of this intake is that if it was to take on ANY moisture, it will not breakdown like paper filters.
Scotty
Scotty
Originally posted by GreenZ
Actually, when you install a BHAF you must remove the stock air box. All the cold air from the front, under and fender are then exposed to the filter element of the BHAF. I didn't realize this untill I installed AK RAM's system on my rig. I will need to put a hole in the end of the canister to get the cold fender air but I am getting the cold air from the front and bottom with Brian's set-up. I just gotta say that I dont' think this system can be beat - with this system you get the most air of any filter (largest surface area), Clean air, cool air, no oil which means no inconsistency, and cheaper than any other system! Thanks AK, kinda glad it wouldn't work with your twins
My RamAir sure helped on EGT's - - that must tell you something. It spools up quicker and cut my time down when towing in my 50 to 80 mph tests. And I am stock other than the filter and a heavy size 12.
Bob
Bob
Originally posted by BEHRMAN
Scotty sucks.......
.....air that is.
Scotty sucks.......
.....air that is.
I blow HOT AIR
The Scotty Systems S U C K !
COOoOoooOooooOoooooOOOOooL AIR!
For some reason anyone I talked to in marketing said my SLOGAN was not a good one.
nfsommer
Apr 16, 2007 09:21 PM
hellotbone
Dec 9, 2003 12:32 PM
CTDCAL
Mar 31, 2003 01:43 AM
