It's Turbo Time! Htt 62 or 64?
Current mods are in my sig. Eventually I plan on studs, springs, cp3 upgrade, Flux injectors.....
I know my little stocker turbo has got to be crying with the insane drive pressures and EGTs. I have been contemplating turbos for a little while and feel fairly confident I will go with an HTT 62/71/13ss or 64/71/13ss. Eventually I may add a turbo and have a set of MPI twins...but that is on down the road. So in the mean time........which of the 2 turbos listed would be better for my truck and my use.
I tow a heavy toyhauler loaded down with water/ATVs etc. usually once a month or so. 20K gross, truck and trailer. But I want to be able to go play at the race track without backing off due to EGTs.
Would the 64 be to laggy? This is my daily driver and I don't want to regret going to big or to little. This may be an easier decision if I had a 6speed. 64 for sure. But since I now have a built DTT automatic which direction? Thanks for any and all input!
I'm looking for the same info. I have a trailer that weighs less; I only gross out at ~17K. So HTT 62/71/13ss or 64/71/13ss?
I figure that with an exhaust manifold and a cam, the lag will be a lot less. Add some F1.5 sticks and it should be good. The question I have is will the 64 surge while towing or daily driving?
What made you pick the 71 over the 65? Are you going to get injectors?
If you are towing heavy and to me 17k plus is pretty heavy, get a 62. If you need a cam, sticks and intercooler to make a 66+ turbo work you may as well just do twins. Also, any of the 62 class turbos work perfect on a set of towing twins, so when you want more turbo you will already have the "little huffer".
Get the 62/71/13ss and get an exhaust manifold of your choice.. BD is an ATS, I've heard HTT has a 3rd gen manifold, but I haven't seen it.
It works really nice towing a very heavy toy hauler... We use my wifes truck with the 62/71/13ss and it works really well!
Chad
Chad
I'd say with having the auto to get the 62... I had a Super 62 and it blew up and I tried the HTT QD 64 and man I can't believe the differance on the top end with it compared to the 62, but for everyday driving I'd say the 62...
I wanted to keep the drive pressure down in the higher RPMs. I figured a Silver 62 (74mm) would probably be a little too big to spool up.
I knew deep down that I should stick to the 62, but a 64 would be so much more fun while not towing. I also figured that a 71mm wheel would be okay if I added a cam, exhaust manifold and [small] sticks to help spool it.
Now, the next question. How does high altitude (7000'+) affect the turbo choice (both towing and non-towing)?
Ok thanks guys! Sounds like the 62/71/13SS is the answer.
I just know im gonna add some stix and be pushing more power than it is "rated" for, in the not to distant future. Everything is a compromise, I know. I Just hope it doesn't get to toasty, until I get the twins (if I ever get them)......which was one reason for inquiring about the 64, instead.
