installing an isspro pyro
i am installing an isspro pyro on an 2004.5 quad cab 4x4.i have 2 quetions:first is what color wire to tap off of the headlight switch for the gauge lights .
second the instructions say to connect the red wire off of the the signal amplifier box to the ignition.i dont understand where to do this.
thank you for any help in advance
I am not sure if any wiring changes were made to the 04.5, if it the same the wire you should connect to is orange with black stripe. I powered my gauge light s from one of the spare fuse blocks found in the fuse box under the hood. Box is located on drivers side in front of battery.
The fuse blocks are hot. I just placed a 5 amp fuse in the block. My gauges came with a small brass fitting that fit over the leg of the fuse and pushed it in the block. I used a spayed connector to connect the wire to the brass fitting.
GSP
Sep 28, 2005 07:17 PM
abryant
Apr 29, 2005 05:17 PM
Diesel fitter
15
May 29, 2003 06:40 AM
