Sponsored by:
Sponsored by: DashLynx
installing CB radio
Old 06-11-2005, 12:13 PM
powerstrokin03's Avatar
installing CB radio
Finally got the CB in and installed it last night. When i keyed up the mic the engine idle speed fluctuated about 50 rpms. What causes this and are there any filters that need to be installed to fix this problem. Thanks.
Old 06-11-2005, 01:59 PM
Mike_Boutet's Avatar
I would first find a different place for the power. Where or what did you tap into?
power is straight to the battery and so is the ground.
Old 06-11-2005, 02:04 PM
DR3500's Avatar
where is the antenna lead routed? if it is routed too close the the engine wiring it could cause this.
Old 06-11-2005, 02:06 PM
right next to the wiring harness of my quad? is this the problem?
Old 06-11-2005, 02:15 PM
Most likely, try rerouting it and see if changes. Good luck.
Old 06-11-2005, 02:19 PM
what would cause the CB to alter the engine
Old 06-11-2005, 04:53 PM
Buckshotmckee's Avatar
Re: installing CB radio
I can't think of anything that would cause the idle to fluxuate????? I scotch locked my power into the cigar lighter, grounded it to a metal brace in the dash, routed antenna cable along frame and into the cab under the floor shifter.
Old 06-11-2005, 05:34 PM
Administrator / Scooter Bum
Shovelhead's Avatar
RF interference can do some pretty amazing things.
We used to have Motorola "Brick" radios that, when keyed up within a couple of feet of a computer monitor, would cause the screen to blur.
Old 06-11-2005, 10:43 PM
SuperGewl's Avatar
RF can make your computer due alot of wierd things. As others have stated, try rerouting the antenna cable and also install yourself a fuse panel in the truck with a relay connected to the cigerette lighter so that its only on when the truck is on. Works gret and lasts a long time
Old 06-12-2005, 12:08 AM
CarolinaThunder's Avatar
Exactly what kind of radio and what kind of "BOX" are you runnin? Mine seems to dim my lights! and you can see what i'm runnin in my sig.
Old 06-12-2005, 08:06 PM
Miles PH's Avatar
Two things happen win you key up RF single is getting to your BOX'S 100 HP & VA . I had the same problem last year till I changed my CB rig and DAVE Made to a lower power. I'm now running 140 EXzillarator. And ran all Zillerbox cables not close to antenna or power for CB. Good luck
Old 06-12-2005, 08:29 PM
Hav'nt got a chip yet so that 1.6kW is'nt botherin me to bad, just my lights!
Old 06-12-2005, 08:37 PM
Miles PH's Avatar
Thunder from down under next time Skip arunning I am gonna give ya holler "sneaky snake" Dave made 2 pushing Little bit . Were in Charlotte NC are ya?
Old 06-12-2005, 09:22 PM
Thanks guys, ill have to re-route all the CB wiring and see what happens. Thanks again
Quick Reply: installing CB radio
