Installed RAPTOR 150 Pump -- Lower boost!
Switched out my walbro pump for a raptor 150 pump. I also installed the twin line kit for dual injection pumps.
With the walbro pump I would get 64lbs of boost. With the Raptor pump and twin line kit I get maybe 54lbs of boost. I increased lift pump pressure to about 30psi. Still no change. Why the change in turbo boost? If anything I expected more. |
Turn the Raptor down to 20ish...maybe 25. No need for it to be up there so high.
Does it fail off much when you hammer it? |
