Installed a bigger intake on the Puller: PICTURES!
Old Jun 7, 2007 | 02:00 PM
PourinDiesel's Avatar
Old Jun 7, 2007 | 02:02 PM
The element is a Stage 2 AFE w/6" opening. It replaces a Stage 1 Magnun (94-02) that had the 4.5" opening.
So far low end torque and throttle response is up a hair. Noise is about the same or a bit louder.
Old Jun 7, 2007 | 03:18 PM
tbarbee1's Avatar
Very nice who's tube is that between the rubber fittings?
Old Jun 7, 2007 | 03:21 PM
Are you talking about the grey colored tube? Its an old AFE torque tube when they were made from iron.
Old Jun 7, 2007 | 03:34 PM
wap's Avatar
wap
That looks awsome, what where you runnin prior?
Old Jun 7, 2007 | 03:35 PM
WUnderwood's Avatar
lookin good Justin
tbarbee1's Avatar
OK I'm with you now. So now its basiclly be the same as the stageII setup without the little shroud. Right??
Old Jun 7, 2007 | 03:40 PM
Basically the same setup but with a smaller stage 1 type filter with a 4.5" inlet flange from a 2nd gen Magnum Force intake.
Originally Posted by WUnderwood
lookin good Justin
Thanks Will.
Basically, yes. No room for the stage 2 system under my hood. I have had the stage 2 several times in the past but I didnt install because I thought the plastic torque tube would melt under loaded conditions when it contacted the outlet pipe from the Aurora turbo.
Of course now the Stage 2 box just wont fit due to the ARB air compressor being mounted in front of the battery box.
The reducer pipe that goes from 6" to 4" is a spare exhaust aluminum pipe I had laying around from a prior purchase. The bottom piece that connects to the Aurora 5000 is a stock piece from the common rail "S" pipe. The 4" 45* rubber boot and clamps were purchased from intakehoses.com.
Old Jun 7, 2007 | 03:47 PM
tbarbee1's Avatar
Great info and pics thanks Pourin.
trailinone
May 29, 2011 07:15 PM
PourinDiesel
21
Apr 30, 2007 09:55 PM
R & A Equipment
Feb 26, 2007 11:27 PM
Rancho71
15
Sep 1, 2005 11:55 PM
Mopar_Mudder
May 1, 2004 08:28 AM
