installed 315, looking to get rid of rub
Ok, so my 315's rub a little more that I would like, Can I put blocks under the front like you can the rear? IMO a leveling kit throws off the geometry of the suspension, I haven't looked at the axle but wouldn't blocks keep the geometry stock? I can buy a leveling kit loacally for $300 installed, Are the blocks safe?
DO NOT use blocks. Look at every lift kit ever amde for any 4x4 ever made. NONE of them use blocks in the front. If you think the spring spacers will mess things up, that's nothing compared to what blocks would do. i had a friend in high school that decided to do that in a 1/2 ton chevy pickup and it would barely go straight down the road and couldn't be driven on the interstate at all.
I put in the 2 1/2 or 2 3/4 " spring spacer leveling kit.. No problems so far and my 315's don't rub (18K miles).. one thing though.. they do not come with a spacer for the sway bar and I have bent the little ends on that connect on the sway bar end. I just made a set of 2 1/2 inch blocks to make the sway bar angle proper. I guess when you top out the suspension it bends the links. I went into 4 wheel parts and skyjacker makes a swaybar spacer but they are $35.00 each side.. Looking back at the time I spent making my block I should have just dropped the $70.00..
levelling kit
I had the levelling kit installed, next week I hope to get the 2'' blocks fro the rear. should I have my truck aligned, even if it goes straight down the highway? it will for shure need aligned afetr the blocks
Gerry
GatorRam
43
Feb 4, 2011 09:43 PM
Bersaglieri
13
Sep 10, 2009 10:48 PM
Lark
Feb 10, 2007 06:39 PM
henchman
Feb 15, 2004 08:10 PM
