Install for Carli Starter kit with track bar and alignment?
Does $700 sound high?
That was my quote at the closest Carli dealer. |
I got quoted $480 to install my Thuren suspension (springs, mini packs, swaybar endlink, trackbar, all four shocks, shock towers) at my local Dodge dealer. That's 8 hours at $60 per hour. The quote you got seems reasonable but it's probably on the higher end.
I got quoted $400 including alignment. Granted, labor and parts are somewhat cheaper in this area than most others.
Seems kinda high to me. Where are you located?
Seattle, WA
Theres alot of good guys out in the NW. Surely someone can help you out. $700 just sounds high to me (I installed my lift with a friend and got it aligned for $80).
$700 is too high!
I had my Lorenz System installed (same components as Carli Starter) for $500 including alignment.
