injector recomendations
truck has bd tow twins edge w/ add and hot unlock code.also has a fass fuel system
trucks a stick and tows a 15k trailer was thinking of a 100hp F1's but im not sure how the smoke will be while towing the 5th wheel. was also looking at II injectors my major issue is dont want lots of soot. any info would be great. Thanks |
There is a member here towing heavy with Flux 3.3's. Although I wouldn't personally want to do that.
With that said, I think Flux 1.5- Flux 2's are all doable with your turbo and what you are asking for... |
Ive had good luck with II injectors on my truck and common rails. they give good clean power and are decently priced
II 2 or 3 flows or DDP 50hp stixs if you tow alot.
