Injector rattle with pressure boxs?
Old Jun 14, 2006 | 10:41 PM
Smithereen's Avatar
Is it normal to get an injector rattle when you install a pressure box? I put mine on not long ago, and it make me queezy when I step on it and I can here it rattle. It doesn`t when I turn the box off. Any input would be apretiated. thanx
Old Jun 14, 2006 | 10:45 PM
BothellDiesel's Avatar
I would stay away from high pressure boxes, If your hearing noises it probably not good. Are we talkin about the Van Aaken in your sig
Old Jun 14, 2006 | 10:47 PM
Van AAkens are pretty mild from what i've heard
Old Jun 14, 2006 | 10:52 PM
RamWheelsBy4's Avatar
I do not have any rattleing with the EZ stacked with HOT Juice or TST. I tried an early version of a DR Performance Stage II when they first came out for the 04.5 and the rattleing were really bad. I took the box off after a week. The next week I had to replace injector #6. Can't for sure blame it on the box, but that was over 40,000 miles ago. Had the EZ stacked with other boxes for at least 20,000 miles now and no problem. Seems some pressure boxes are easier on the injector pump and injectors than others.
Old Jun 15, 2006 | 12:27 AM
Smithereen's Avatar
Ya the Van aaken is the one I have. Just trying to figure out if this is common or not.
Old Jun 15, 2006 | 07:20 AM
MikeyB's Avatar
I have a little more injector rattling at lower rpms under load with the EZ. But I also have the Rokktech crankshaft sensor.
MikeyB
Old Jun 15, 2006 | 07:26 PM
Smithereen's Avatar
Wonder if it is hard on the injectors? Or if there is any proof.
O5DodgeRam5.9
22
Aug 12, 2007 05:17 AM
midwestdually
14
May 8, 2007 11:51 PM
whtractor
May 27, 2005 01:49 AM
Feb 5, 2003 05:24 PM
Pa outlaw
Dec 22, 2002 09:05 PM
