drillpipe |
04-07-2007 09:30 PM |
Injector Problems/Questions
Installed a set of 75 hp ATS injectors last week, and had a bit of a problem with them this morning. Today I had Smarty on #7 and EZ on 1st level, did a WOT run and after getting off the throttle it kept fueling for about 5-8 seconds and was running very rough during this time. Since this is my first experience with aftermarket injectors, just wanted to see if this was a common occurence or do I have some hosed up injectors? It ran perfect during the runs no missing or cutting out. After a couple of WOT runs it would do this over fueling just trying to drive normally. Dropped Smarty back to #2 and it runs fine. I have the Smarty loaded with the aftermarket injector/turbo program.
