injector??
after getting my trans built which should be soon. im thinking about injectors.. my truck has 227,000 miles on it with no injector problems to date. would i be ok in just buying nozzles or should i go ahead and get complete injectors? im looking at a set of 90hp if that will help and or make a difference. any help or info would be appreciated.
Originally Posted by doc winters
(Post 2932991)
227k.....I would buy 6 brand new bodies/solenoids, and the tips of your choice, new cross tubes, and add a 2 micron filtering set up, if you don't already have the filtering.
Then I would send the originals into a reputable shop for testing and rebuilding if they are salvagable, or you may be able to sell/credit them towards your new sticks. I would not put new tips on bodies that have 227k use, and install on my truck, unless Don M, possibly Dynomite, had a chance to test and repair first. |
jjpage is all that nes even if im not having any fueling issues as of now?
(Post 2933754)
If I was not to buy new injectors, I would send my used injectors off to Formula 1, through one of their dealers, and have Don M rebuild them with his custom tips for our 03 CR's. If your tips are ok, Don can extrude hone yours to a desired horsepower, this is what he did with mine. He was out of blank stock when I sent them in, so I could wait, or have my tips modified. He modified them to flow equal to a F1.5(70/75HP), no complaints, but my injectors had 17k on them when Don received them. |
bump
Definatley get them tested. New injectors could also fail in 10 miles with water or debris flowing thru them at 26k+. As long as they check out I would run them. Usually costs about 30 per to have them flowed. It's always good to have them flow matched after the new tips also. So for 60 a piece for 2 flows you could sleep better at night. IMO
