I want a wide stance, what wheels should I get?
Old Oct 3, 2008 | 10:51 PM
cwgtex's Avatar
Question I want a wide stance, what wheels should I get?
Ok I just purchased the Carli starter system, which I'm told is +2.75in of lift in the front and +1.5in in the rear. I'm waiting for it to get here so I can install it.
Once installed, with the extra clearance, I would like the widest set wheel/tire combo I can without rubbing. I want to stick with 17in rim. I want either 33x12.50 or 35x12.50 Toyo M/T. What are the ideal wheel specs I should look for?
Would any of these wheels work?
MB Predator 17x8 5.5in BS
MB Predator 17x8 4.25in BS
Desert Rat Raton 17x10 4.5in BS
Old Oct 4, 2008 | 06:29 AM
mikmaze's Avatar
do ya like the look of the H2 rims / tires ? they give it a great stance and if ya can find a set of fresh take offs with tires, the price is usually good. sets the truck a good bit wider, and hangs the tires outside the wells enough that you can use pocket flares without it looking stupid.
Old Oct 4, 2008 | 09:12 AM
Townsend600's Avatar
If you want something that sticks out pretty far you need at least a 10" wide wheel and probably around 4.5" of Backspacing. H2 wheels just aren't for me. The don't have much more BS then stock wheels.
Old Oct 4, 2008 | 11:42 AM
cwgtex's Avatar
whats yours
Townsend600, I look at the pictures you have and I like the look of your truck. What is the width and backspacing on your wheels? They don't look like the KMC XD badlands that you have in your signature.
Old Oct 4, 2008 | 01:56 PM
My avatar pic is from awhile back.
Those wheels were 17x9 pro comp 1079's with 315/70/17 Hankook Dynapro MT's. 4.5" of BS.
My badlands sit out just as far.
Old Oct 4, 2008 | 01:59 PM
I was going to try and upload some pics but it said I had already uploaded them into another thread. It won't let me post pics more then once?
Old Oct 4, 2008 | 07:42 PM
rip 112's Avatar
4.5" backspacing on a 2wd! Just for reference...
Old Oct 5, 2008 | 12:38 AM
hotrod929's Avatar
I really like the 17x10 Raton wheels with the 4.5" backspacing. How bad would these stick out on an 05 with the Lorenz 3" leveling kit? Thanks
HotROd
Old Oct 5, 2008 | 12:43 PM
Took some more pics of the truck after I cleaned her up yesterday.
4.5" BS 18" KMC XD Badlands
Old Oct 5, 2008 | 01:56 PM
jwb600's Avatar
get the 10" wide wheels the 8 wont stick out like what you want I dont think you will be happy with the looks unless you get a wide wheel. Ive got some 12" wide wheels for sale in the classifieds they stick out a little about 8" past the fender wells haha
Old Oct 5, 2008 | 02:10 PM
KMC says my wheels are 9" but when you put a set of wheel calipers on them the are 10" wide.
Old Oct 5, 2008 | 07:18 PM
Hicksy's Avatar
would 4.5" of backspacing on a 10 inch wide wheel rub with a 2 inch leveling kit....33 inch tires btw
Old Oct 5, 2008 | 07:30 PM
it doesen't on mine, not even when flexed out.
My tires are 12.50's They might with 13.50's or 15.50's I don't know.
Old Oct 5, 2008 | 08:40 PM
cwgtex's Avatar
clearance
Townsend, how much clearance do you have with those wheels and 33s? And is that clearance only with the 2.5" leveling kit in your signature or is there more you had to do to fit them?
Old Oct 6, 2008 | 11:36 AM
cwgtex's Avatar
Arrow predator wheels
Also is anyone here using the MB Predator wheels from discount tire? If so what lift/tire combo are you using?
