HTT turbo coming tomorrow, gasket included?
Old May 1, 2008 | 09:33 PM
jmccart's Avatar
Hello. It is scheduled to hit me tomorrow from UPS. Does it come with a new gasket for between the turbo & the manifold?
Thanx.
Old May 1, 2008 | 10:01 PM
Spooler's Avatar
Yeap, it will come with a gasket, two nuts and bolts, two short studs for the back two holes, and a resistor plug for the electronic waste gate. At least mine did.
Old May 1, 2008 | 10:39 PM
jmccart's Avatar
Good news on bolts/studs. When I put on the ATS manifold, I mickey-moused some non-matching washers that I found in my garage. Do the new bolst come ready to work nicely w/the ATS manifold?
Thanx.
Old May 1, 2008 | 11:01 PM
trx's Avatar
trx
what turbo did you end up going with?
Old May 1, 2008 | 11:11 PM
Spooler's Avatar
They should work fine. No washers needed except for the supplied ones.
Old May 1, 2008 | 11:14 PM
jmccart's Avatar
I ended up getting an HTT 62/71/13ss. I got it from Lloyd at Mid-Atlantic-Diesel. Been talking turbos a bunch with homewrecker & rip112. They love the turbo. I was going to order the 62/65/13ss. I told him I ran 4.4/level 9 daily. He suggested the 71.
Next a Helix 2.
Old May 1, 2008 | 11:17 PM
Spooler's Avatar
It will work great for ya. Glad I got the Smarty it spools my 62/71/13ss just like stock on mild TM and level 9. Haven't pulled with the Smarty yet though.
Old May 1, 2008 | 11:19 PM
trx's Avatar
trx
that should be a sweet set up!! You guys running the 71 tow very much?
Old May 1, 2008 | 11:25 PM
jmccart's Avatar
I can't wait to get-er-dun. I hope I feel a big kick in the ole' butt. I tow a 35' travel trailer whenever I can.
Old May 2, 2008 | 12:04 AM
THURENfab.'s Avatar
I suggest running the stock gasket if yours comes with the thick graphite one...
I blew a chunk out of mine, and have been meaning to suggest to HTT that they don't supply the fat brittle gasket..
Old May 2, 2008 | 12:22 AM
jmccart's Avatar
Interesting. I used the copper one when I swapped manifolds. I have a lil' exhaust "tick" somewhere.
Thanx.
Old May 2, 2008 | 10:22 AM
homewrecker's Avatar
I tow my GN trailer with mine(10K-12K lbs) with no problems.Cruising temps are a little higher than with the 62/12 I used to run but hit the go pedal and it lights up and maintains good egt's.I have no regrets what so ever with going to this turbo.
jmccart, get that thing on there and let us know what you think!
Old May 2, 2008 | 10:32 AM
jmccart's Avatar
UPS says it is out for delivery.
I will be back.
Old May 2, 2008 | 12:03 PM
THURENfab.'s Avatar
Thanx.
I have no gasket in mine now and it's great haha!!
I suggest pulling the whole manifold to swap the turbo like it mentions in the direction. It's quite a bear getting to the new back bolts, the new turbo doesn't fit by the motor mount to get over the factory studs, and you can't run bolts in the back since the new housing is so big.
Just plan ahead to pull the manifold..
Old May 2, 2008 | 12:08 PM
jmccart's Avatar
Cool info, I won't even try studs then.
Thanx.
