htt 64 turbo
i am going to be getting a new turbo in a couple weeks and was wondering how the htt 64 71 13ss would spool on my truck. everything i have is in my sig but i plan on getting some flux 3s mid next year then will be using it in a set of twins some time after that. my truck is a daily driver but i also race it. will the 64 be ok or should i get the 62?
thanks for the help |
With the 64 it is going to be laggy. Get the 62.
My friend is running the same turbo and boxes....He LOVES it!
yeah 62 the way to go unless you are eventually going to be over 600 horse
well i want to break 800 and would rather just get the 64 now if thats what i would need since it is my daily driver. if the 64 wouldnt be too laggy it would be a lot better than having my truck down again waiting for the turbo to get upgraded.
Originally Posted by ShakinRedCTD
(Post 2638810)
Have you updated the tranny yet???? If not, you need to do that first.
tranny can be done anytime, im just waiting till i can get the springs, studs, injectors and o-ring the head so i only have to take it in one time.
If you get the 64, it's going to be a little laggy with stock sticks. When I first put my turbo on, I did not have my injectors, and the lag was so bad I had to manually shift from 1-2-D.
After the sticks... :D |
yours is a 16 would a 13 make much difference?
Yes, however, you will still have lag. The 16ss flows like a cast 13...
I love my 62!
I mean, don't be scared! But, just know, with out the fuel to spool it, you're going to have some EGT problems on the low end.
thats one thing i am worried about, will it be ok cruising down the hwy? im just worried that when i get the injectors the 62 wont like them. what is the hp range of the 62?
Not sure about the Flux 3's but my flux 2's / Smarty and the Silver 62 are perfect together.
Topper |
| All times are GMT -5. The time now is 12:55 AM. |
