HP Estimate
Whats your alls opionon on my HP?
05 6speed Cummins Edge Juice, Bully Dog Power Pup and b1 charger? Wes |
Just a guess,
I'd say between 475 and 500hp.
Use Crazy Lary program, Hot Juice, stack an EZ for pressure and you'll probably be over the 500HP. Then you will be ready for studs and twins, then probably need a FASS and a set of injectors to get to the next level:D .
That's my goal anyway. |
The Crazy Larry program already pushes pressure to the max, so I wouldn't be stacking an EZ. With Twins, Piers used a TST and Crazy Larry to put down about 675hp.
The Hot Juice by itself will probably get you 475hp. |
So the BullyDog Power Pup will do enough fueling without a pressure box stack. That means I need to forget the EZ and get the Power Pup. Anyone want to trade a Power Pup for a Quad XZillaraider Race box?
I do know the HOT Juice on Level 5(180hp) is a BIG jump from Level 4(100hp):D , just cant really find out how big until the trans/tc are done:( . |
You know! People think I'm crazy with the little bit of mods I have done. You guys are REALLY nuts!!!![laugh]
Thanks, i was thinking somewhere in that range, need a dyno!
Another question, Ive asked piers about injectors in these CRs, when running something like the PM CR and Ez stack or the juice / powerpup set up he said that you wouldnt get a large amount of increase in horsepower. Those of you with injectors was there a large difference? Is it worth the $$$? Wes |
Go look for the Piers posts on TDR. He said he is waiting for new injectors to add to the TST and Power Pup stack. Think he said together with twins, TST, Power Pup stack was 650hp or more. He was looking to add new injectors to see if they could hit 700hp.
