How to test in tank pump psi??
Winner winner chicken dinner!
You can test it at the fuel filter. Slow to start can also be injectors, you may want to double check the Torque specs of you injector tubes, rail lines, etc.
When you turn the key to the run position (don't crank it) you should hear the pump running.
Think it may be fuel pressure regulator on CP3..
Can here pump running fine.
Just checking everything it could be
38 Cigarette
16
08-28-2015 11:27 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
