Hot" Juice Stacked with - EZ
Well I finally Installed the Edge -EZ To stack with the Hot Juice I already had installed,
Results[coffee][coffee][coffee][coffee][coffee] Definately Nice Pull off the Line Fill Now, And Some Noticable Smoke output, clears up quick Nothing like my 2-nd Gen with the Edge Drag Comp and mach-4 150-HP sticks, I felt Like Bat Man laying out the Smoke Screen on that Truck. A definate Nice addtion to the Hot" Juice with Attitude. I am only using levels One or Two on the EZ as I here this is High as you want to go on the EZ Fueling Side. So Far Stock CP3 , Stock Injectors, undecided Next move would probably be a Dual CP3 set-up dual stock pumps, And then some 70-90 Max HP injectors. I have a Joe Hellmann Intercooler on the Way to help keep down some of this addtional heat , |
How far do you plan to take the truck? If all you plan to add are some small injectors, you aren't even close to needing dual pumps. You can get a modded pump for a whole lot less money from Floor It or Darksidedieselworx.
